What is the current lowest mile g1 insight
1 reading
5.5K views 29 replies 15 participants last post by  Foos
#1 ·
Curious on if there is a lower mile g1 insight than my 60k original miles with carfax, dealership and dmv records.
#12 ·
The last time I drove an Insight was 4 months ago. Any Insight driven now would feel GREAT!
#19 ·
No IMA light or CEL light, no problem.
Where are you located?
#23 ·
Dogbite: Original owner won it in a contest, but was too old to register or drive it. Car sat in the Houston sun for over a decade. Restored by second owner, who then sold it to @jime.
Sawbite: So-named because the entire right side of the car was cut away, to show off Honda's technology. Car spent its entire life in a museum, except for the year plus it took to import it into America. I fully restored it back to driving condition (leaving the cutaway portions as-is). Honda definitely didn't want this car to ever drive again, but now it does ;). I donated this car to the Lane Motor Museum in 2020.
#25 · (Edited)
Just a little bit more, Dogbite was a barn find in Houston, TX by member 02insight and his friend lach. As mentioned, it was parked outside for many years and the paint was badly damaged. The local large dog had gone at the hood edge and the left front fender with some pretty powerful teeth. When I registered the car in VA, I was pleased to find that no one had claimed the vanity plate name "Dogbite" and it was so named. The discovery part of the story is told here:
02insight became the owner and with his friend lach, they lovingly nursed the car back to healthy running condition. They grid charged the battery, which remains strong to this day, and changed out all the fluids. They also had the wheels restored and put on new RE-92s.
My wife and I were traveling the U.S. by motor home at the time and happened to be going through Houston on our way to the southwest for winter. Out of curiosity, I arranged to see the car. I was immediately smitten with the absolutely new quality of the car, less paint of course. The more we socialized, ate and talked my lust for the car just grew and grew. I'm afraid that I made a significant contribution to 02Insight dental school tuition with my offer, but I have never been the slightest bit unhappy with the car.
I was towing another insight at the time, so plans were completely changed. I now had two Insights in Houston. What to do now? I decided to tow Dogbite to my sister's home in MS, and return by bus for the other Insight. Rode the Greyhound back to Houston where 02Insight picked me up at the bus station. Now I had two Insights in Mississippi. More bus rides and finally got both cars to VA. Never did make it to southwest that year;)
I did some additional restoration myself. I disassembled the brake calipers for inspection since my prior experiences had told me that stale brake fluid would collect water and rust these parts. I found some slight rust so replaced the pistons, rubber parts, and hardware with new parts. After much discussion and anguish, I decided to get a quality paint job. If the car had "patina" I would probably have kept the paint original, but with the dog damage and sun damage the exterior cosmetics were just aweful. I also purchased a bunch of new exterior trim pieces at the same time. This thread relates some of my ownership time:
Since I want to keep the mileage as low as possible, it is pretty much a garage queen:)
#28 · (Edited)
The entire process is agonizingly cataloged here.
Summary:
Back in 2001 Sawbite toured Canada (on a trailer) to show off the cutting edge technology (i.e. being a hybrid, which was new hotness at the time). After the tour ended, it spend around 16 years at a museum in Canada. A few years back, the museum deaccessioned Sawbite, which was essentially sold for scrap. @Natalya found the car for sale online, but was too far away (Atlanta) to purchase it. Instead, @rhall (in Canada) purchased the car, and then sold it to me. I then spent well over a year importing it into the United States, which was incredibly difficult because it's nearly impossible to import a salvage vehicle that's less than 25 years old into the US. On the advice of my attorney, I'm gonna gloss over the details on how we got Sawbite stateside. ;).
Once Sawbite got into the US, I drove up to Detroit, where @minor4326 helped me load it onto a trailer in sub-zero temperatures. I then drove it back to my garage, where it then sat for over a year. When COVID hit, I figured that was the perfect time to get it running again. The two primary reasons the car wouldn't drive were:
-Honda cut every single wire harness in the car in half. I hand-repaired every single harness.
-Honda cut the firewall continuously from the left to right A-pillars. This significantly weakened the frame, to the point that sitting in the car caused the 'gap' width (where it had been cut) to change. Rewelding the firewall back together was challenging, but only because the first company I took it to did a terrible job.
-The fuel injectors were entirely fouled up... sitting unused for 20 years caused them to not work. I was able to repair them by running higher voltage through them for several seconds, and then dipping them in a cleaning solution.
-The coolant system was disabled in several different ways.
-To prevent the engine from running, some kind of gummy material was poured into the oil filler. I ended up using a solvent to dissolve it all.
-The car had no fluids whatsoever, except for a completely full gas tank (which I emptied out and burned in my truck). @rhall had previously poured in some oil, which was good because the car sat outside for a long time during the importation process.
-The SRS system was entirely disabled.
-I added back and/or repaired all crash safety parts required by NHTSA, so Sawbite can legally operate on roads. Sawbite is street legal (in TN, at least). I almost had to register it as an ATV (off road vehicle); it meets all the legal requirements to be an ATV in TN.
After fixing the above issues, the car worked just fine. I drove it about a mile, then donated it to the Lane Motor Museum. It's amazing just how quiet a brand new G1 Insight engine is... absolutely zero valve tapping.
#27 ·
Search ICN for "sawbite" and the whole history can be found.
IIRC started around 2017.
